CentralCoastCamExplorerJul 06, 2013Landing gear motor moving.I discovered when retracting the landing gear under load, the entire motor assembly rotates counter-clockwise about 1/8 of the way around. This has resulted in a gouge in the motor casing by a set scr...Show More
abc40kidsExplorerJul 06, 2013Mine moves also, when I first hit the switch it will rotate like you said and when u let off it comes right back.
Related ContentLanding gear motor.Replacing front landing gear box and motor.2019 attitude landing gear motor issuesEver upgraded landing gear or motor?landing gear dual motors
