jvawter
Sep 18, 2015Explorer
Landing gear operates only with vehicle cable connected
The landing gear used to operate just from the battery on the 5th wheel, or when the cable was attached to the vehicle. I was unhooking from the hitch when the cable caught on the tailgate of the truck and pulled some wires out of the terminal box. I opened it up and found a ground pulled out and one wire skinned and a wire pulled out of a wire nut. I put the wires back and insulated the skinned wire. When I went to operate the landing gear it wouldn't work. I plugged in the cable to the running vehicle and it works. I checked the 30 amp fuse to the motor and it's good. I can't find any other fuses for the landing gear. Does anyone have any idea what might have happened to prevent the landing gear from operating as it used to without the vehicle connected. If the connected vehicle isn't running, the landing gear won't operate. It's getting power from the running vehicle. I check the DC fuses in the converter panel as well.
