laknox wrote:
Glad it was a simple issue. Make =sure= you get the 2 legs sync'd before you install the new bolt, though. :-) FWIW, 32" of extension isn't bad at all. I've had near-40 on one site; lowest step was nearly on the ground. :-) FWIW, at our usual boondock site, I have to extend the legs nearly to the ground before I drop the extensions, then drop the nose nearly 2' from the hitched position to level. Tail ends up so high that I have to put a small step under the folding steps. :-)
Lyle
Yup. I plan to count the holes to sync it up - with a little finessing to get the holes lined up. And I will visit my local RV supply house to see if they have a footpad to replace the crushed one. Otherwise, they sell them on Amazon and I can have it in 2 days.
