Just a note, the drop legs are 31" long and I wouldn't extend them to the last hole, which on mine, is 4" from the end of the leg. If I remember, there are 16 or 17 holes above the foot, depending on what type of foot you have. With that set-up, you're going to have to be careful about how level of a campsite you get. If you get a downhill campsite, you're not going to be able to drop the front enough to get the trailer level, and it's no fun to have to put jacks under the frame and have to reset the frot jacks so you can lower it more, trust me, been there done that. You'll also have to watch the clearance between the trailer and the back of you r truck bed. If you have a sharp downhill, your trailer may contact the truck bed. I had that happen and my truck isn't even lifted. If you  have a Ground Control 3.0 Auto-Levelling system, you'll get a fault code if it is out of range.
