dryfly's avatar
dryfly
Landing gear/jack problem
One landing gear on my 5th wheel has began to make a terrible noise. Sounds as though it is binding when lowering or raising the trailer, and is coming from one of the 2 1/2" square tubes located inside the storage compartment.
I pulled the top cover from the tube and apparently the two gears are in good condition and are turning. In fact, I believe the assembly is still raising and lowering the trailer, but the binding sound is so severe I hesitate to do this because something is going to give.
I have worked on just about everything on a trailer but not these assemblies. Any idea where I might find a diagram of whats inside the square tube? From a little searching, these legs may not be re-buildable but may require replacement of the entire leg.
Any help or ideas appreciated.
  • sjturbo wrote:
    I'm not an expert by any means. I had the same binding issue. Mine was my fault. The inside consisted of a captive nut that the threaded rod moves up and down through. If the rod, or the square tubing gets tweaked, (even a slight bend), it will start to bind. That results in an increased load on the motor and drawing more amperage and blowing the fuse. Worse is the stress it puts on the threaded rod. That can result in the rod breaking,(which mine did) with very dangerous results. I would not hesitate to replace the leg!! Those legs are lifting a lot of weight!! I increased my weight by going from 1 70lb battery to 4 63lb batteries. Hope this helps!
    That is exactly how I pictured the inside mechanism to be. I still have not found a drawing to substantiate the exact configuration though. I was hoping that I could take it apart and replace the rod or lubricate it where it goes through a captured nut. May not be possible.
    Probably calling Lippert might be a start.
  • I'm not an expert by any means. I had the same binding issue. Mine was my fault. The inside consisted of a captive nut that the threaded rod moves up and down through. If the rod, or the square tubing gets tweaked, (even a slight bend), it will start to bind. That results in an increased load on the motor and drawing more amperage and blowing the fuse. Worse is the stress it puts on the threaded rod. That can result in the rod breaking,(which mine did) with very dangerous results. I would not hesitate to replace the leg!! Those legs are lifting a lot of weight!! I increased my weight by going from 1 70lb battery to 4 63lb batteries. Hope this helps!
  • Have you seen this page? Not much there but it looks like two pinon gears.
    Ah way down the page is a drawing.
    Hope this helps some.
    BK
