Dave_Wilburn
Feb 05, 2013Explorer
The front and rear jacks level the trailer. The middle jacks only come down to act as stabilizers when the others have it level. The middle and rear jacks only have 4" of stroke (if they were longer. They would stick up through the floor).
When you park the trailer, cycle through the screens until it tells you exactly how far out of level you are. You need to get the trailer to within 1 degree of level side to side first. More than that and the rear jacks won't have enough stroke to get it level. Id you are on a soft surface, dig small holes for each tire and park with the tires in those holes. On a hard surface, drive onto blocks to raise the low side. Once that is done, drop the front landing gear and unhook. Then raise or lower the front until the trailer is within 1 degree of level again. Then put blocks under the rear and middle jacks. The. You are then ready to push the auto level button.
You have to get it close the old fashioned way, it then does the fine leveling and stabilizes the trailer. Once you do it right a couple times, you'll get the hang of it and you'll be set up drinking a beer 5 minutes after pulling in.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
