gravessat
Feb 05, 2013Explorer
Giggitygoo wrote:gravessat wrote:
I had the same problem, I had to manually calibrate it, you dealer should be able to give you the instructions.
However every now and again the center jacks will not come down all the way and I have to do another autolevel.
Do your center jacks come down last when they do work?
Yes and now that I think about it I bet my battery was low when I had the rare problem with the center ones not coming down all the way.
If I were you I would get the instructions and a long level and level it and calibrate it yourself on a flat hard surface the first time, they told me the sensor was on the underside of the floor above the middle axel, I also made the front just a little higher than the back, but not much that way my AC condensation drip was at the back when the AC was running.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
