Hi All, The roof on my 5er (Wildcat 28BH)has started to leak near the front. I went up there to see if there was anything obvious wrong, but it all looked fine to me. Is there something I can app...
I had a small leak on the front of my camper. It was at the metal strip where the rubber roof meets my front cap. It was leaking as the screw heads were not properly sealed. I got some Dicor Self-Leveling sealant and proceeded to fill the metal track to seal it permanently. I also used some Dicor Non-Sagging Lap Sealant to re-caulk areas that looked questionable. If the current sealant is cracked in any way, you should re-seal it.
