- Sam_SpadeExplorer
ventrman wrote:
All of my Questions have been answered. I will just leave the door propped open with the Frig shut down. Thanks everyone.
It is also a good idea to wipe down the interior about 24 hours after shutting it down.....if you are able to do that. - VeebyesExplorer IIDepends on the size of the battery bank first of all.
Second, why leave it on if you won't be there for weeks? - Old-BiscuitExplorer III
352 wrote:
The question was how long would a fridge run on a 30lb tank. Not how long the battery would last or power to run the converter. I think he got the answers for both.
Re-read OPs 1st post...... - ventrmanExplorerAll of my Questions have been answered. I will just leave the door propped open with the Frig shut down. Thanks everyone.
- 352Explorer II
Old-Biscuit wrote:
352 wrote:
ventrman wrote:
When leaving my 5th Wheel for an extended Period without Electric hooked up, how long will my Frig work on a full 30 Pound Propane Tank?
On low in central Fl. in the summer, empty, with an interior circulation fan was 28 days. The reason I know this is because I also wanted to know. So I filled one up and turned it on and 28 days later it was empty. And I tried it on electric for 28 days and checked the kilowatt hours. Gas is for sure cheaper.
And during those 28 days you must have had some means of battery charging.
OP would be running off of battery......no charging
Fridges only uses roughly 2200btu per hr (or less)---roughly 291 hrs of run time on a 30# (7 gal) cylinder
The question was how long would a fridge run on a 30lb tank. Not how long the battery would last or power to run the converter. I think he got the answers for both. - Old-BiscuitExplorer III
Fridges only uses roughly 2200btu per hr (or less)---roughly 291 hrs of run time on a 30# (7 gal) cylinder - Sam_SpadeExplorer
ventrman wrote:
the Reason I was asking is......
That does not explain why you would WANT to leave the frig on for 6 months even if you could. - 352Explorer II
On low in central Fl. in the summer, empty, with an interior circulation fan was 28 days. The reason I know this is because I also wanted to know. So I filled one up and turned it on and 28 days later it was empty. And I tried it on electric for 28 days and checked the kilowatt hours. Gas is for sure cheaper. - 2oldmanExplorer II
ventrman wrote:
This forum is playing tricks on me.2oldman wrote:
I have not changed my Profile. I have a 2006 Forest River 5th Wheel.
I was going to see how old your 5er is, but your profile shows a DP. - fj12ryderExplorer IIIJMO of course, but if I was leaving it for 6 months I'd empty the fridge, turn it off, and prop the doors open. Why take a chance that something may happen to shut down the fridge? That would be one horrible mess.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
