alank2's avatar
alank2
Explorer III
Feb 21, 2026
Leaving generator wet or not
So I've had a Yamaha ef3000 for 15-20 years now and I have used a technique on it that has worked so far, but I wonder if it is the best strategy or not.  I only use double treated Stabil non-ethanol gas in it, but admittedly sometimes the gas is a year or two old, and still I haven't had a problem.  It always runs.
I leave the fuel turned on and always leave the carburetor wet.  My theory has been that if it is wet, it can't dry up and gum things, especially with the Stabil.
I keep reading though that people should turn off the fuel and let the carb run dry.  Is that a better method?  How do you ensure it is really dry?  My concern there being that even if you let the engine die, does that mean the carb is really empty of all gas?
I'm thinking about buying another gen now and wondering if it will put up with the same treatment of leaving the fuel on/carb wet, or if that is a bad idea.
  • If it’s been working for 15 ,20 years, your method isn’t “wrong,” but most people prefer running the carb dry before long-term storage to avoid varnish or gum buildup. Letting it die on its own usually leaves a tiny bit of fuel, but with Stabil-treated gasoline, the risk is much lower. Either method can work; the key is just consistent maintenance and fresh fuel when you start it back up.
  • I use premium gas without additives in my Onan 5500. Wet all the time. Not a problem so far - 13 years. I do run it once in a while.
    • StirCrazy's avatar
      StirCrazy
      Moderator
      premium gas (and it all has additives, I am assuming you mean no ethanol) goes bad just as fast as regular gas.  I would hazard to guess you use it often and for long enough peariods through out the year that it never gets to the point where the fuel is breaking down, or you have been pretty luckey which is cool also.
  • I run my generator once a month until it warms up. My fuel is always treated with Stabil year round, not to stabilize fuel but to clean (Double Dose). My unit runs itself dry at shutdown.
    • Grit_dog's avatar
      Grit_dog
      Trailblazer
      That’s a lot of extra work….
      suppose if you’re looking for things to keep busy with, not so much, but is that the only small engine you have? Or do you run the “fleet” every month?
      Maybe one of these days I’ll understand…. No, doubt it.
      If it runs dry on shutdown what is the point of starting it?
      • Popspastime's avatar
        Popspastime
        Explorer II
        It has a starting battery in it to keep charged so I run it to keep it tip top. Lot's of work? I can see we have two different ideas of maintenance and taking care of stuff. Quit a few small engines here and guess what,? they all start and run great using my method. To each his own.
  • alank2's avatar
    alank2
    Explorer III
    Let me add another question to this - what if a generator has some varnishing going on, but not enough to stop it from running.  Is there a good additive to the tank that after running a tank will tend to clean up any varnish deposits without hurting anything else if it is left in the unit for awhile.
  • alank2's avatar
    alank2
    Explorer III
    To summarize; it sounds both methods work fine.
    One can leave it fully wet including the carb as long as they have stabilized fuel (I've always double treated 4oz per 5 gallons)
    -or-
    One can turn off the fuel and let the engine die so it runs dry
    • Grit_dog's avatar
      Grit_dog
      Trailblazer
      Yes and ….no.
      Wholly dependent on more conditions than just stabilized fuel or not.
      Fuel stabilizers don’t last forever. And I’d challenge the notion that they keep fuel viable for more than 6-12mo max.
      They don’t magically eliminate evaporation, they slow evaporation of the lighter hydrocarbons keeping gas “fresh” longer.
      would I use it “over winter” without question? Yes.
      over a year? Nope
      Other factors, plastic or metal tank, temperature swings, hi and lo temp, susceptibility to moisture intrusion, E10 or no E gas (E10 is actually good for “some” things like absorbing moisture it’s like adding heet to your tank).
      Bottom line, it’s better to do something than nothing.  And whether it’s sufficient depends on a bunch of factors that often get lost as petty details.
      Example, I parked both my mowers last fall. Both carburetor engines. A newer 35hp Kawasaki and an OLD 12.5hp Kohler.
      Between moving cross state and new job, selling, buying a house, frequent travel etc, I left them with plain ole 87 octane from guessing early October. Didn’t even remember to run the carbs dry.
      fired both of them up last week to load and haul to the new house. Both started and ran like they had been started the day before on fresh gas.
      Lucky? Maybe
      Got them going before fuel went too rotten? Likely.
  • old fuel can still varnish even if it is wet,  in as little as 2 months.  you are useing a fuel stabalizer in it, I had to look it up to see what you ment,  so you should be fine over the winter and just start it up and burn it through in the spring.  a stabalizer usaly is good for up to 6 months.    I used to do that, then I switched to running the carb dry as my genny hardly gets used and even with stabalizer I was getting gunking as somtimes it wouldnt even run during a season.  now I am back to wet but I am using synthetic fuel for the last tank.  doesnt need a stabalizer, doesnt break down at all and it is always ready to go.
    • Grit_dog's avatar
      Grit_dog
      Trailblazer
      Synthetic gas?  Holy fffff. Well that’s one way to do it.
      Hard to believe the cost is worth the convenience to…anyone.
        StirCrazy
        Moderator
        I only put about 1 gal in, I was trying to see if stuff would stay better wet with a fuel that doesnt go bad, ever. I decided to dump some in and see how long it would go.  and from what I have seen if you never use somthing it is better to leave them wet.
        it is actualy cheep when you buy it in the bigger jugs.  I do use it exclusivly in my weed wacker and my post hole digger.
        I used normal gas in my genny but I ran the tank dry, then I put in the synth gas.  that was 8 years ago.  and it will still start second or third pull, sometimes first.  so Iam not realy running it on synth gas, yes that would be pretty expensive, but if I ever do need it I will use real gas and then just run it dry, put synth fule in it and start it for a miniut to get it all in the carb and put it away again.  I only start it once a year, originaly just to make sure it would start, now to see how long I can go with this synth fuel.
  • As an FYI, my Honda 2200i has a control that valves the fuel and switches the ignition. Turn it part way toward off and the fuel stops, all the way it kills the ignition too. It also has a screw to drain the carburetor. I didn't realize it had these features initially, and after storage it ran poorly. Now fixed; I always run it until it dies, switch off the ignition, and further drain the few drops left in the carburetor.  I'm guessing the manufacturer thinks it must be important to get the fuel out before storage.
  • Your fuel treatment OCD is likely just enough to combat the effects of old gas.  Maybe combined with a pinch of luck.
    evaporation happens regardless. And some carbs evaporate out slower than others.
    for example I have an old Jeep that will seemingly keep fuel in the carb for a long long time and most every other carb from weed whipper to Edelbrock 750 evaporate out much quicker.
    So do what works imo as long as you’re aware of the effects you’re good.
  • Fifteen to twenty years seems like a “proven result” to me; why change what seems to be working.
    I start my generator at least once a month and let it run for about 15 min (generally I put at least some load on it 20% - 75%). In the winter I may start it twice a month or more depending on prevailing temperatures). I generally only keep a minimal amount of gas in it and freshen it often. Every 6 mo. or so I will drain it, put the old into a can with 6 gal of new, then pour a some back into the gen.
    I have a second gen at the cottage. This one sits all winter without being started. So I run that one dry in the fall when we close up for the winter. Other than that, I do the same thing with that one.
    • alank2's avatar
      alank2
      Explorer III
      I am wondering if the Yamaha just put up with it, or if it was a good plan.  If I get another generator, will it put up with the same or not.  I find it interesting that there hasn't really been a consensus here, some leave it wet with stabilized fuel and some cut off the fuel and run the engine until it dies.  My concern with that has always been does that really use up all the fuel in the carb?
        StirCrazy
        Moderator
        it uses up almost all the fuel in the carb, still will be a tiny bit left in the bowl.  but the important thing is it gets the fuel that will degrade out of the small pilot holes and needle valves and such in the carb, thats where it does the most damage.  now wether leaving gaskets dry or not is a good thing, thats a whole new topic.  I know when I used to prep outboard motors for winter storage, we would run them on fogging oil after the fuel was cleared out to coat everything so it wouldn't oxidize or dry out.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
