I only put about 1 gal in, I was trying to see if stuff would stay better wet with a fuel that doesnt go bad, ever. I decided to dump some in and see how long it would go. and from what I have seen if you never use somthing it is better to leave them wet.
it is actualy cheep when you buy it in the bigger jugs. I do use it exclusivly in my weed wacker and my post hole digger.
I used normal gas in my genny but I ran the tank dry, then I put in the synth gas. that was 8 years ago. and it will still start second or third pull, sometimes first. so Iam not realy running it on synth gas, yes that would be pretty expensive, but if I ever do need it I will use real gas and then just run it dry, put synth fule in it and start it for a miniut to get it all in the carb and put it away again. I only start it once a year, originaly just to make sure it would start, now to see how long I can go with this synth fuel.
