shum02
Dec 28, 2017Explorer
Tank heaters are around 40-60 watts, just enough to keep the liquid in the tanks from freezing and most AC powered ones are thermostatically controlled. If you leave them on and the tanks are empty you will more than likely cause no damage to the tanks but probably will burn out the tank heaters.
If you don't need them on, don't turn them on and as said they will not help the water lines/sewer lines in the least.
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
