Gray_Fox's avatar
Gray_Fox
Legs on my HitchHiker
I have a 2009 H H an I put down the legs to far so now the buttons will not work up or down.
did I blow a fuse or burn the motors out.
  • Anonymous's avatar
    Anonymous
    Not applicable
    If it not an electrical or motor problem the worm gear may be stuck since you say that you lowered the legs all the way. My HH has a manual crank handle that can be used to operate the legs. Check yours for this option.
  • If you didn't blow a fuse, then you know the motor died. Ours did about 3 years ago and it cost about $250 to replace.
  • Follow the wires from motor back to battery...should be an in-line fuse or a DC Circcuit Breaker
