RobWNY
Aug 17, 2019Explorer
I guess I don't understand what your issue is. You've explained how you're nose is too low but in the pictures you look nose high. So if that's an illusion, and your nose is too low, first, you have your front jacks pads extended to the third hole. Put them all the way in and you gain a couple of inches there or extend them out depending on the situation. You have several inches of travel with the motor and the pin locations for the pad give you several more inches. You just have to find what combination works on every site. If sloped too much one way or the other, I would get a different site. In most cases I use lynx levelers under my front landing gear. I've had a dozen on each side at a couple of sites. They not only get me level and when my jacks aren't extended very much, they sturdy the trailer.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
