DutchmenSport
Aug 17, 2019Explorer
JRscooby wrote:
Can you put blocks under the frame near jacks
I just measured the distance from the ground to the frame. Currently the distance is 28 inches on the longest side. So, a stack of lumber 24 inches would probably do the job, as that would not hyper extend the front landing gear. Lower onto the stack, then retract jacks and put more lumber under the jacks and raise again.
Thanks again. The more I think about this, the better I like it. Now .... lumber (ugg!).... or 2 steel cages or frames 24 inches high capable of supporting 1500 pounds each.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
