CarnationSailor
Aug 17, 2019Nomad
DutchmenSport wrote:CarnationSailor wrote:
If there were no restrictions, what would be the distance the jack travels from fully retracted to fully extended (ignoring the extendible section)?
Just measured, since they are completely extended right now ... 13.5 inches. That the length they extract. The inserts can add another 8 or 9 inches in total length, but not sure, I've never had the trailer high enough to completely slip them out of the sleeve. So, really don't know how long they are.
My Level-Up jacks can extend at least 24 inches - probably more although I would get nervous if I ever had to have them extended that far. (They are a single solid piston rather than having a manual extension.)
I think the heart of your problem is that your jacks can extend only 13.5 inches. It doesn't matter how far you extend them or how tall the blocks are that you put under them. You are not going to raise the front of the trailer more than 13.5 inches after backing onto the site. (Unless you employ the solution that involves support under the frame which seems like it should work.)
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
