Edd505
Aug 28, 2019Explorer
Bipeflier wrote:
Are you starting with the jacks fully retracted and drop the inner legs to the ground? If you do that you should be able to raise the front of the camper at least 2 feet. If you don't drop the inner legs you will never have enough stroke.
That was my thought, why not drop the inter leg? I have the Ground Control 3 auto level so there is no inter leg. I just est how low the front will be and add a stack of legos to make up the distance. I use them under all the legs all the time as the shorter the leg the less wobble.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
