K_Charles
Nov 14, 2016Explorer
don't use the jacks to hold up the trailer but hold the jack up with something. If you remove the line that makes the jack go up the weight of the ram might make the jack fall and you would loose fluid. If you leave the trailer on the truck and hold up the jack you are fine. If you loose a little oil in the line it will replenish the first time you use it
About Fifth Wheel Group
19,036 PostsLatest Activity: Apr 08, 2026
