kymikecastle's avatar
kymikecastle
Levelease or Intellijacks replacement?
All,
Wondering if anyone has found a replacement to the (evidently now closed?) LeveLease or Intellijacks system? Not sure what happened to the company, but cannot find any current info... The system is/was great in assisting with raising/lowering the front landing gear during connect/disconnect/retracting.
I would love to purchase another unit (for use in older rig), but have not found anything comparable.
Thanks!
  • Thanks for the suggestions - but unfortunately, the Lippert unit mentioned above is a true leveling system at a cost of several thousand. What the "LeveLease" or "Intellijacks" system did was an automatic raising/lowering of the front landing gear only. It had different settings, such as "connect height" (push the button to raise your fifth wheel automatically up to the correct height for connecting), "auto level" (raise or lower landing jacks to a horizontal level), "retract" (retract landing gear fully). It was a fantastic design for older rigs that did not have the full "leveling" system, all for a couple hundred bucks. Would love to put one of these units on some farm equipment! (think gooseneck flatbed trailers, cattle trailers, etc). Thanks!
  • Shrek51 wrote:
    This system should work. Check etrailer.com
    Lippert Ground Control 3.0 Electric 5th Wheel RV Leveling System w Touchpad and Remote - 6-Point Set
    That looks like a good alternative.
  • This system should work. Check etrailer.com
