Old-Biscuit wrote:
rhagfo wrote:
Greene728 wrote:
travel4fun wrote:
Our family has just purchased a new 5th wheel that we are excited about. My TV has a 4" and I had the dealership flip the axles and added (1) 4" spacer on each side of both axles to help level the trailer to match up to my TV. After connecting the trailer it looks that it is nose high and still not level.
Look at the pic in my profile to see my set up. I am curious if I still need to add taller spacers or if this looks ok. Currently I have 9" of clearance between the bed rails and the bottom of the trailer.
Thanks.
Based on the pics and your description (9 inches of bed clearance) either raise the pinbox a notch or lower the fifth hitch down in the frame a notch.
On a side note, I would be terrified pulling that camper raised that high. Stability has got to suffer set up like that. You also have quite a bit of squat on the TV (which is a beautiful truck BTW). But bags would only amplify your nose high problem I know. Good luck to you, but that set up would drive me nuts. Lol!
:h :h :h
With a 1,128# pin I think it is more the photo angle than squat!!
It would be nice, if you could get a good side view on a near level surface.
That 1128# is 'dry' pin weight........probably closer to 1600# when 5vr is loaded which could be close to 'payload rating' depending on truck's trim level
5rv doesn't look level......looks nose high and with 9" bed rail clearance 5vr nose can be lowered via adjustments of pin box/hitch
Hard to tell with that off angle squished photo in sig about truck squat and/or 5vr nose high
As for the method used to lift 5vr........not a fan of using spacers.
Sq. Tube subframe welded to trailer frame with sq/tube cross bracing is a tried/true method.
Even at 1,600# way below the GRAWR, even a newer 2500 will not drop much without 1,600#. I carry about 2,200# and squat 1-1/2".
I agree with the tube sub-frame for anything over 2".
This has been a couple years in the getting this level.
