travel4fun wrote:
Thank you all for your comments and suggestions. I have created a list of items to do to try and fix this issue.
1. I will first raise the pin box two sets of holes and I hope this will put the trailer between 5" to 6" of bed clearance.
2. Look at a different tire setup running LT 16" radials on the trailer (the RV dealership welded the spacers to the axles so that will take quite a bit of work to remove them) or changing the tire size on the TV (its about due for new tires anyway).
3. If those two things don't work then I will look at adjusting the suspension on my truck.
Also, I will look at addressing the squat on the TV after I get the truck and trailer as level as I can get it. I have already began looking at different types/styles of air bags to install to reduce the squat on the TV.
Any more suggestions are appreciated.
Fix the squat of the truck first as that will affect everything else
