Cummins12V98
Nov 16, 2015Explorer III
I have the LCI 6 point system on our 16 MS. I have not spent the time to figure it out completely but it seems to work well. I had no problems with the last MS with the 4 point manual system.
I can say the lower area of our 16 is more stable than the 07.5 it replaced but the lateral movement in the upper bedroom area is MUCH more with the 16 then the other MS. The rear 4 hydraulic rams are very solid but the two front rams appear to be in some sort of sleeve and there is a LOT of movement. Everything appears to be tight up front. I am assuming this is normal?
About Fifth Wheel Group
