laknox
Jan 27, 2015Nomad
Artum Snowbird wrote:
It has occurred to me that if I was to set the front electric leveling jacks with one touching the ground and the other a few inches from touching, the touching side would begin to level the unit from side to side before both jacks make contact with the ground.
Is this an acceptable way to set up the rig? It almost seems better than putting blocks under one set of fifth wheel wheels because then the pin would not be into the hitch jaws quite right.
How do others adjust for side to side leveling with their rigs?
Level side-side with the =wheels=, using boards or "lego" blocks. Level fore and aft with the jacks. Personally, I level side-side first, then run my front legs down a ways, and drop each leg extension all the way to the ground. I then power out the front legs until the pins snap in and continue to extend until I unweight the hitch. Open the hitch, pull forward and park the truck. Level fore/aft with the front legs, then drop the rear stabilizers to "set" it. I also will use several boards for cribbing under the rear jacks so they don't extend as far and give a bit more stability.
Lyle
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
