kemer wrote:
We have a 36' unit with the self-leveling system. If I park it in my driveway with the rear end on the high side and deploy the auto jacks, it wants to raise the front end up high enough that the front wheels are off the ground. Whats the best way to handle this? Can I raise it up, put some blocks under front wheels, then lower front end until tires rest on blocks?
Thanks
Kemer,
Well, in reality, the first thing you need to do is, LEARN your coach and all of its systems. You don't say what make of leveling system you have so, I can't assume it's just like mine although many people think all motor homes are built exactly alike. But, IF, your leveling system is like ours or, is built like ours, then you should be able to level things MANUALLY, rather than do it automatically.
There are many reports on here about auto leveling systems raising coaches too high, even on flat ground, much less off camber situations.
So, the first and smart thing to is, find, build, buy, acquire some STABLE leveling blocks that you can use to DRIVE on, not only at home but, if you've got the room in the coach storage, to also take with you when on traveling trips. They're ALWAYS HANDY to have. Then, once you have them, you can drive up on them, in your own driveway and, them MANUALLY level the rest of the coach.
It doesn't matter if your jacks are strong enough to lift the coach TOTALLY off the ground. That's not the point. The point and, goal is, to get your coach as close to level as possible WITHOUT raising the front tires off the ground. This way, your motor home will be considerably more stable by having as many "TOUCH" points on the ground as possible, i.e. all six tires and, all four jacks.
And, your jacks don't have to work as hard, trying to level you and, you don't end up tweaking the frame or, body or, windshield etc, trying to achieve level. Good luck.
Scott
