LLeopold wrote:
Ummm. Some clarification is in order from the post in Beginning RVing.
All from the CA DMV Recreational Vehicles and Trailers Handbook where one may download a copy from: https://apps.dmv.ca.gov/pubs/dl648/dl648.pdf and from the CA DMV license chart available at: https://www.dmv.ca.gov/pubs/cdl_htm/lic_chart.htm#classc
Assertion #1: If you are a California resident, to legally pull a 5th wheel with 15K GVWR in California, you must have a NON-COMMERCIAL CLASS A license.
Clarification #1: You may pull a 5th wheel that is 10K GVWR or less with a Class C license. You may pull a 5th wheel between 10K and 15K GVWR with a Class C license with a "Restriction 42" endorsement (I have this particular endorsement and it is not well-known at the DMV). Over 15K requires the non-commercial Class A license.
Assertion #2: To legally pull a travel trailer (bumper tow)with 10K GVWR, you must have a NON-COMMERCIAL CLASS A license.
Clarification #2: One may pull a travel trailer that is 10K GVWR or less with a Class C licence. Over 10K does, indeed, require a non-commercial Class A license.
Assertion #3: To legally drive a Motor Home that is 40 ft or greater, you must have a NON-COMMERCIAL CLASS B license.
Clarification #3: One may drive a motor home that is less than 40 ft. with a Class C license. Over 40 ft. does, indeed, require a non-commercial Class B license (a non-commercial Class A is also permitted).
If we're going to cite items, let's try to be as complete as possible and include citations to official sources.
As to visitors, the state recognizes other states' licensing to a degree. Double or triple towing (5th wheel towing a boat, for example) gets a bit dicey.
Hope this helps with full clarification.
Error Correction for Clarification #1. It's a "Restriction 41" not "42" and it is not considered an endorsement. Actual wording on the back of my brand new drivers license:
Class: C - Veh w/GVWR <= 26000, No M/C
ENDORSEMENTS: None
Restrictions: 41-Class A restricted to operating 5th wheel travel trailer between 10,000 and 15,000 lbs GVWR
Double or triple towing:
The only drivers allowed to do so in California, require a Class A Commercial license. I think it has to a California license.
