larry_barnhart
Aug 26, 2014Explorer
hook47 wrote:
TXiceman, not sure where you got your information on DRV products but if you go to their website you will find that they use a triple boxed 15” frame on the MS and ES. My 38’11” MS has a GVWR of 18.5K, the same as the LS39FB 42’11” which has a 18.5K GVWR. I questioned DRV about my GVWR because similar sized Elite Suites were rated at 20K and their answer was it was a matter of paper work and my Mobile Suites is built on the same frame/running gear and I can go to the 20K rating. I don’t care who makes the frames, in house or Lippert. The important thing is if the frame is spec’d appropriately to do the job. Can’t recall reading about frame problems on DRV products. DRV
You have not read everything because some have had problems but I have not read any lately. Not every rv problem is on rv.net.
chevman
About Fifth Wheel Group
