Mile High wrote:
RustyJC wrote:
Mile High wrote:
I did see that, and I downloaded the brochure which also shows the Titan box frame, which is curious, but the pics for the new ones show the 6 pt leveling which is inherent to the I-beam. That along with the rumors I heard, I have the feeling the brochure and website have not been updated.
The 6 point leveling system can be used with a box frame. Our Mobile Suites has 6 point leveling and a 15" stacked box section frame (2"x6" plus 2"x6" plus 2"x3" with an additional 2" box section riser between the frame and MorRyde independent suspension.)
Rusty
Ya I forgot about those. Regardless, I think Lifestyle dropped the Titan box - went to I-beam.
I remember the Dealer bragging that the Lifestyle box frame only needed the 4 point Big Foot system because the frame didn't flex like the I-beam. Seeing the 6 pt on there in the picture means they changed their mind, just decided to go to the LCI Level up, or they truly did go to I-beam.
If they truly did drop the Titan frame, it makes it interesting to listen to all this hype they had for the box frame in 2014
Lifestyle - Titan
In my experience the fact that Lifestyle uses the 4 point system is because that is what Bigfoot sells. I suspect that BF made them a good deal on price. The stacked frame on the Lifestyle ends just behind the wheels, which is where the jack is. The rest of the way back is single box frame that will bend if jacked in the rear.
