michigancougar wrote:
thanks, the pin box is all the way up - axles are already under the springs - I will measure next time it is hooked up but gussing only about 6" max on bed to camper clearance .
is the 2" that the correct track set up be worth the effort?
I have no opinion on the Correct Track, as I have no experience with it. I'm just repeating what others here have said. I like Tom's pics and what he did, though were I to have done it, I think I'd've liked the sub-frame to be about 6-12" longer on each end, just to stiffen the frame around the suspension. His is definitely more extensive than you might need and, if prices I've seen quoted here in the past couple years are any indication, it's not really that expensive. Personally, I think it might actually =improve= resale value, especially for someone who has a newer truck that's almost certainly going to be taller, and putting the buyer in the same boat you are.
Lyle
