ifd22's avatar
ifd22
Lifting fifth wheel
My 2019 fifth wheel that towed level with my 2007 Ram 2500 2wd, now tows 5” nose high with my 2018 Ram 2500 4wd.
I’ve adjusted the pin box all the way up, and couldn’t raise it higher if I could due to bed clearance.
I plan on taking it to a local commercial spring shop to have it lifted 4”-5”. They said they do them all of the time, and they plan on welding a new sub frame on and reattaching the spring hangers.
Has anyone ever “had” a bad experience lifting a trailer?
It’s fairly obvious that higher it sits, higher the center of gravity becomes, but has this ever caused anyone an issue?
They are charging $600 which sounds reasonable considering the work involved.
