Hello everyone, need to pick your brains. I have an 06 Silverback, it has brackets at front and rear of leaf springs shackles and two more holes to be able to lift the unit. Would it handle a lot mor...
Do you have sway? Your post makes it sound that way, unless that 5er is real nose high or extreamly pin light, you should have zero sway pulling a 5er with a 2500. If lifting the 5er it becomes closer to level you will likely solve any sway issue.
