ToneDog wrote:
Hi all. Been lurking for a couple of years and researching 5vers and TTs. Probably looking to buy sometime this year. This will be my first towing experience and my girlfriend and I will use it primarily for extended weekend type trips.
I'm looking for suggestions for light 5vers. My tow vehicle is a 2015 F250 6.7L Diesel. Payload will be a limiting factor since it is SRW. I weighed the truck with a full tank and 2 passengers, came in at 8,350. At GVWR of 10,000, that leaves me about 1650 left for kingpin weight and hitch. The truck came with the fifth wheel prep package.
I've been looking at Jayco Eagle HT and Keystone Cougar XLites. Have seen some with hitch weights in the 1200lb dry range, and there are dealers close by which is nice. Any thoughts on these or others that I should consider?
Thanks all!
Another FW to consider, if you want to spend a bit more, is the KZ Durango 1500 line.
Lyle
