Old-Biscuit
Feb 02, 2014Explorer III
Your truck probably has a GVWR of 9200# with a RAWR of 6084# and a max tow rating (under idea conditions) of 12,000#
Numbers on Data Plate....door jamb
Go weigh your truck camp ready (you, all passengers, fuel, stuff in cab/bed)
Subtract that actual scaled weight from trucks GVWR......difference is available pin weight (5vrs typically run 20% of trailers GVWR---ie: 12K trailer GVWR would ~2400# pin weight)
Also look at available rear axle weight and rear tire load capacity.
Once you have the scaled numbers......finding a 5th wheel within your trucks weight rating capacity is easier.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
