goukcats
Feb 02, 2014Explorer
There are several "lite" RVs available that are lighter in weight but still have decent features & quality. My current 5er is a Cougar High Country & some people are towing these with Ford EB half tons. I did tow mine with an 08' GMC 2500 6.0 gas. I was very pleased with the tow capability of the GMC & only changed to diesel so I could use cruise most of the time on long trips.
Someone else also mentioned Montana HC. Your TV should also tow some of those floor plans just fine. Check the pin & total weight.
Check out some of the various "lite" RVs & compare their quality to the other RVs for yourself. You might be surprised. If someone has actually owned a "lite" RV & has negative comments, you should probably listen.
The materials & processes are much better today than they were even 10 years ago. Some things are lighter and stronger. Check dealers stock & reviews from "lite" owners; then make an informed decision. Good luck & happy trails.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
