- dedmistonModerator
hvac wrote:
I would reach out to all metal construction. ATC or Sundowner, possibly Beck custom trailers.
Does ATC give you a dollar every time you recommend them? - hvacExplorerI would reach out to all metal construction. ATC or Sundowner, possibly Beck custom trailers.
- Wild_CardExplorerMy Voltage Triton 2951 loaded and ready to rock is up inbthe 3200# pin weight. No 4 wheelers i am 3500.
- lincsterExplorerIf u are looking to offset pin weight with toys then don't count on it. I put a 2800lb sand rail in mine. Motor/transaxle/ rear tires/ hubs..... all behind the back axles and my pin weight still goes up.
- 2001400exExplorerDo you want a separate garage or not? We went without one so I bought a forest River which is 32 feet long total (model number is 28). There is a 36 foot long one as well. This is the stealth, shockwave, sandstorm model lines. They can be had around 50k fully loaded.
Eclipse has similar toy hauler in the attitude line as well in the same price range and they are the pin weights you are looking for. - 2017 KZ Sportsmen Sportster S373TH12
This one is a little longer than you want but it is light, 10,650 empty. The website I looked at didn't have a pin weight for it. - rhagfoExplorer III
wing-shooter wrote:
yes, unloaded pin weight as we have dirt bikes and atv. Most of that weight should be closer to the tail end or over the axles.
If you make the pin too low of a percentage of total weight it will lead to Chucking and could also cause swaying even a 5er.
If you want a big toy hauler step up to a DRW. - wing-shooterExploreryes, unloaded pin weight as we have dirt bikes and atv. Most of that weight should be closer to the tail end or over the axles.
- JAC1982ExplorerCheck out the Voltage Triton line. I don't know what their pin weights are but they're in the price point you mention and don't have stuff like auto leveling and fancier features, so they weigh less. I know the model we looked at that was the same size/layout as what we ended up buying, but was about 1,000lbs less.
- lincsterExplorerSo do u wanted a fully loaded pin weight in that range?
My unloaded pin weight is 2680 lbs.
Once I fill water, load up and put my 2800 lb sand rail in, I have a pin weight of 3450lbs.
About Fifth Wheel Group
19,042 PostsLatest Activity: Sep 03, 2026
