Thermoguy wrote:
I'm not to familiar with the Ram Mega Cab, but I don't think you need to worry about hitch weight. Your issue is, like most, payload capacity. With a SRW and wanting to haul a toy hauler you are going to have limitations anyway. If you are worried about a 200-300 lb hitch vs a 100 lb hitch, then you might be looking at too big of trailer. You can add too much weight to the trailer by throwing in some more stuff or adding firewood to the bed of the truck or something. One of the posts mentions a 3500 payload capacity. So, as long as the trailer you are looking at isn't coming close to that payload, then the weight of the hitch isn't an issue. You should get the hitch that fits your needs and truck trailer usage not shop by weight. I would consider an Anderson if I didn't already have a B&W but simply because I have both a 5th Wheel and Gooseneck Trailers. If I didn't have both, the 5th Wheel hitch would be all I would need.
Just make sure the trailer pin weight isn't pushing the limitations of your truck and you shouldn't have to think about it. But, also remember, those numbers are not struck in stone. Some will feel the truck is overwhelmed even if the trailer isn't close to the actual number on paper, and others will feel they can go hundreds of pounds over that number. Just depends on the person, where you are driving, and your experience.
Good Luck
Good points, The mega cab is a good choice for its people space however that mega cab is bigger and heavier that the typical crew cab. The size of the Mega Cab ultimately reduces your payload capacity. You can believe in GVWR or you can focus on RAWR either way the size of the mega cab will have a negative impact on the carrying capacity of your truck vs. a non mega cab model.
In the long run you need to choose a truck with adequate payload for what you plan to tow. A lighter hitch will not make up for insufficient payload. If you think it does your numbers are just too tight.
