wra
Sep 14, 2018Explorer
When you check your breaker connection, don't forget to check the common connection (at the outside plug and breaker box). When checking the 12 volt side, be sure to clean the negative connections (at the battery and converter). Since all lights are affected, the negative side is more likely the culprit.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
