time2roll
Jul 11, 2016Nomad
Probably need a new converter. Skip the WFCO and get a PD or IOTA.
Do the lights go out if you remove a battery cable?
For now run down and get a 10+ amp automatic battery charger. Put it direct on the battery. No need to disconnect anything. Pick up an extension cord if needed.
Appliances run fine down to at least 10.5 volts where the lights are real dim.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 29, 2024
