tntcrock's avatar
tntcrock
Lippert 643150?
Need to cap the "T" coming out of Lippert 643150 pump manifold, so I can test for a cylinder leak. What size cap do I need? It has 1/4" ID hose connected to it. I'll also be changing my hoses once I test things for slide creep. The exterior rubber coating is crumbling off hoses.
  • drop by any hyd hose repair/make new shop in your area. They can supply you with what you need
  • Thing I found the info. 1/4" JIC 37 degree flare; that's the hose ends.
