Edd505
Sep 04, 2019Explorer
OP said you can push "Hitch Height" and it will return to the height it was when auto leveled - Only if you have not pushed any buttons.
Here is the Ground control 3 manual https://support.lci1.com/ground-control-3.0-support-ground-control-3.0-onecontrol-touch-panel
Read the section on setting "Zero Point" (level) The system will occasionally hiccup and forget it. Pretty easy to reset but you'll need the manual to walk you through it. I have done it a couple times in 2.5 years and still read as I do it.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
