- Grit_dogTrailblazerAnd just when I thought the OPs question was totally ridiculous….4 pages later I don’t understand why it was a question to begin with but apparently this is another one of those perplexing things….
Walking and chewing gum must also be difficult for some folks who have 5vers too. - Cummins12V98Explorer III
Michelle.S wrote:
I'm with Cummins, have never hit Auto Level after it's been leveled. If I need a minor adjustment, just put it in Manual and make my adjustments.
I learned a lot about the system when I had it retofitted to my 2010 Montana at the TrailAir Facility and talking to the designer of the system.
With 6k pin weight on a marginal system for such a heavy RV I am not going to stress the system by using AUTO.
My RV has two stick on small levels. I used my Laser Level under my RV and adjusted it to perfect "LEVEL" measuring from bottom of the frame at the 4 outer corners. I then applied adhesive to the back of the levels and taped them on "LEVEL". Me being a Commercial perfectionist Carpenter for 35 years likes "LEVEL".
I pulled onto out Southern lot around Thanksgiving and a couple days ago my wife said the bathroom door is swing out so I went outside and sure enough the levels were slightly off and a couple bumps of the buttons it was perfect again and the wife was happy.
The Auto system even if calibrated is not as precise as my system.
First pis is front to back "LEVEL" and second is side to side "LEVEL". I can get mine level just as fast as AUTO but it's not the point.
- Michelle_SExplorer IIII'm with Cummins, have never hit Auto Level after it's been leveled. If I need a minor adjustment, just put it in Manual and make my adjustments.
I learned a lot about the system when I had it retofitted to my 2010 Montana at the TrailAir Facility and talking to the designer of the system. - fj12ryderExplorer IIII have some of the Andersen red round blocks that came with the trailer. I used them several times and then I was flummoxed when one time they wouldn't work. The nose couldn't go down low enough to start the AutoLevel I guess. I took them off, used a couple three of the yellow square blocks and all was well. After I did some more research I started to recognize when I could use the Andersen blocks and when they put the nose too high. Live and learn.
And I'm also unsure about the incremental AutoLevel, but Stickdog says it just relevels and doesn't start from square one. That sounds like a win to me. - Cummins12V98Explorer III
fj12ryder wrote:
I still think that hitting AutoLevel is the way to go. :)
i will admit that I have never hit auto level to just move it a tiny bit so I can't say mine will dip. I can only say it sure drops when I have unhooked from truck and hit auto. - Cummins12V98Explorer III
fj12ryder wrote:
I see what you're saying, and I believe you and Cummins12V98 could be correct. I was laboring under the misapprehension that the levelers will stay where they are set. You're saying that they will level themselves like they do when the pump is running. More weight on the left will cause the left to lower and the right to raise as the pressure equalizes. That sounds reasonable. I was simply too blind to see it.
But I can see raising the left and right could cause the front levelers to become unweighted evenly, hence the trailer would be supported mainly on the center/rear levelers on both sides. But you would almost have to do that deliberately.
I apologize humbly to Cummins12V98. In this instance he was right and I was dead wrong. Sometimes it really does help to consult the brain before engaging the mouth. I hate being wrong, but you'd think I'd get used to it after all these years. :)
Again, I'm very sorry Cummins12V98. Beers are on me.
You are a real MAN I say!!! Thank you for your kind words. - Well said, Ryder.
I once had an occasion when the auto level lowered the landing gear all the way (due to slope) and kept trying to lower. I canceled auto and went to manual. Raising the rear caused all 4 jacks to contact ground then lift the rear. Then I could raise the front a little creating front to rear level. Then the left side needed raised a little for side to side level. Raising the left side caused all 3 left side jacks to extend in unison.
I've only had the 6 jack system since March and that was my first and only time manually leveling. - fj12ryderExplorer IIII still think that hitting AutoLevel is the way to go. :)
- fj12ryderExplorer IIII see what you're saying, and I believe you and Cummins12V98 could be correct. I was laboring under the misapprehension that the levelers will stay where they are set. You're saying that they will level themselves like they do when the pump is running. More weight on the left will cause the left to lower and the right to raise as the pressure equalizes. That sounds reasonable. I was simply too blind to see it.
Again, I'm very sorry Cummins12V98. Beers are on me. - fj12ryder, Cummins12V98 is correct. Once all 6 jacks have a load, they work in unison and never bind. Naturally, when you raise/lower the rear, the front jacks do NOT move. Same when you raise/lower the front - the rear jacks do NOT move. And the same for raising/lowering the left or right sides. Think about what you are saying.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
