Cummins12V98
Dec 23, 2022Explorer III
fj12ryder wrote:
I see what you're saying, and I believe you and Cummins12V98 could be correct. I was laboring under the misapprehension that the levelers will stay where they are set. You're saying that they will level themselves like they do when the pump is running. More weight on the left will cause the left to lower and the right to raise as the pressure equalizes. That sounds reasonable. I was simply too blind to see it.
But I can see raising the left and right could cause the front levelers to become unweighted evenly, hence the trailer would be supported mainly on the center/rear levelers on both sides. But you would almost have to do that deliberately.
I apologize humbly to Cummins12V98. In this instance he was right and I was dead wrong. Sometimes it really does help to consult the brain before engaging the mouth. I hate being wrong, but you'd think I'd get used to it after all these years. :)
Again, I'm very sorry Cummins12V98. Beers are on me.
You are a real MAN I say!!! Thank you for your kind words.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
