Cummins12V98
Dec 24, 2022Explorer III
Michelle.S wrote:
I'm with Cummins, have never hit Auto Level after it's been leveled. If I need a minor adjustment, just put it in Manual and make my adjustments.
I learned a lot about the system when I had it retofitted to my 2010 Montana at the TrailAir Facility and talking to the designer of the system.
With 6k pin weight on a marginal system for such a heavy RV I am not going to stress the system by using AUTO.
My RV has two stick on small levels. I used my Laser Level under my RV and adjusted it to perfect "LEVEL" measuring from bottom of the frame at the 4 outer corners. I then applied adhesive to the back of the levels and taped them on "LEVEL". Me being a Commercial perfectionist Carpenter for 35 years likes "LEVEL".
I pulled onto out Southern lot around Thanksgiving and a couple days ago my wife said the bathroom door is swing out so I went outside and sure enough the levels were slightly off and a couple bumps of the buttons it was perfect again and the wife was happy.
The Auto system even if calibrated is not as precise as my system.
First pis is front to back "LEVEL" and second is side to side "LEVEL". I can get mine level just as fast as AUTO but it's not the point.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
