Bob_Shaw
Sep 05, 2019Explorer
First, there are instructions on the inside of your LP compartment door. What I do is lower the front jacks a little 3-4 inches, then drop the lower drop legs. Then go to manual mode and lower the front jacks to unhitch from truck, stop when the hitch just starts to lift from the 5th wheel. Un-hook and unplug, pull the truck away, (you may have to backup slightly to take pressure off of your hitch to release the jaws), remembering to lower you tailgate first, and then hit autolevel, and it will take over from there. The jacks are solidly built and will easily take the eweight of the trailer, although I wouldn't start out with it so unlevel that it lifts the wheels off of the ground. You shouild also have a cd that explains how to level your trailer. Your dealer should not have let you leave without demonstrating, especially if your new to 5th wheels, and given that some of the auto-leveling systems were miswired, and may not work correctly. Be careful to not move your trailer when the jacks are down, Lippert does not sell parts for the Ground Control 3.0 jacks, just the entire jacks.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
