NEnative's avatar
NEnative
lippert level up error message
My Lippert display shows **on top line, ed on bottom line. The front buttons orange light is on. The left buttons orange light is on. Now its as if I am locked out of the system. Has anyone else experienced this? My front landing gears are fully retracted so I can't hitch up NW. Any advice welcome.
  • The few times that my system has acted up disconnecting then reconnecting power from the battery has fixed it.
  • If you have a manual on your unit it should show you have to override this and rest the leveling system, for our Kz it has such in the Lippert manual an in the operators manual...
    The other thing is to call Lippert at the customer service number, they are really nice folks and can be very helpful ...
    Call you dealer service department if possible ....
    As the OP stated disconnect the 12 volt power by disconnecting the batteries as well as turning off your battery switch ... Then wait about 5 or more minutes so the electronics can clear all memory. You must remember that some electronics do retain memory in some case's, ie your computer still has memory while it plugged in even thought you have turned it off, you must unplug it and wait for a few minutes to clear it head ....
    Safe travels
  • First thing I would try is removing 12 volt power for a bit, which should erase the memory.
