lenr
Sep 12, 2022Explorer III
The Lippert 6 pt system (electric, in my experience, not hydraulic) has limited stroke of the jacks at the middle and rear. The front landing gear have plenty of manual and powered adjustment to get unhooked and level out. Getting unhooked is no problem. I will make a manual adjustment of the landing jacks base on my front to rear reading of my level indicators to make sure there is enough powered adjustment left in the landing gear. The middle and rear jacks have limited stroke and will fault the system when they hit limit. So, if the trailer is more than a few inches off level from side to side, blocks under the jacks will get the trailer to level but "could" lift the low side wheels off the ground. Pulling the low side wheels up on boards fist helps prevent that, but still requires blocks under the jacks to keep them from stroking out. I've done it both ways.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
