MPI_Mallard's avatar
MPI_Mallard
Lippert six point levelling jacks
I have Lippert's six point levelling jacks and i'm wondering how "off level" can the bases/system handle/ In my lot in florida, the concrete area is roughly 3" lower from the right to left wheels and with my older fiver with just the forward and rear retractable jacks I would jack up the left wheels, stack two pieces of 2x8" under both then stack two pieces placed under the jacks and level front to back. Now my new fiver has round disks on all six jacks with little play and i'm worried that that much angle will damage them if forced to sit at an angle.
Thanks in advance!
  • OK,, really appreciate the feed-back guy's!!! Just to "idiot-proof" this when I pull on my lot with the truck still connected I should,,
    -place the 10x10" wedge blocks under the three jacks
    -manually lower the front jacks to disconnect the truck
    -jack up the two wheels and put the 10x18" wedge blocks under them
    -then hit the "auto level" and crack a beer,,,,,am i right?
    again thanks for your help!
  • If you are very far off level, especially side to side, the systems will not level the rig. I do carry some wood blocks to get closer to level so that the leveling system can work. I also carry 4" x 6" blocks to put under the jacks to have less jack extension. The longer the jack extension, the more prone the rig is to wobbling.
    Ken
  • Like above, IF the ground is that unlevel I would use a block or 2 of wood UNDER the ram only to prevent an " Out Of Stroke" warning when leveling.....
    Had my 1 side tires off the ground a few times
  • I use blocks under the low side tires to get the trailer within 2 or 3 inches of being level before I auto level. If I don't the jacks will lift the low side tires off the ground. I have a bubble level on the front of the fifth wheel to help getting it level side to side.
  • Have been on some really unlevel sites where the wheels on the low side end up 4 to 6 inches off the ground.
    Just put some extra blocks under the feet of the jacks on the low side to avoid the possible out of stroke error.
