tntcrock's avatar
tntcrock
Lippert Slide Pump
Is there another replacement option for the Lippert 643150 pump? I need to replace mine and looking for options. I also see it listed as Lippert 141111 w/ 643150 kit. I don't know if this is a upgraded model.
Mine has been been allowing bedroom slide to creep out and now it doesn't close or fully extend the slides. Motor runs but doesn't sound like it's pumping fluid. If I play with it enough it will get them moving, but not correctly. I changed my houses and bedroom slide cylinder last year, so that's new. Did the cylinder test in lippert manual and the cylinders test good.
  • I would say the valve is the problem allowing oil to bypass
  • It the pump raises and lowers the RV's landing gear the pump is not bad. contact Lippert Tech Support they are very helpful.
