rmalik1
May 31, 2015Explorer
Lippert spec'd frame list
Which companies that use Lippert's frames & have their frames made specifically for their 5th wheels. (not a standard Lippert frame) 1)DRV 2)Cedar Creek 3) 4) 5) etc
laknox wrote:I agree with both of you but the majority of folks look at the top side for bling and could care less UNTIL they have a problem.lynndiwagon wrote:
I think most of the problems with the Lippert frames are the sloppy welds. If the manufacturers would inspect the frames supplied to them and reject all with bad welding then you would see an improvement in Lippert's construction.
Lessee, I was saying the same thing, what, 5 years ago...at least? Even if the factory sees bad welds, they should FIX THEM before building an RV on that frame. Deduct the costs from their Lippert bill. If they wanted to be nice, the mfr could reference the s/n of the particular frames with issue so that Lippert could trace back to the welders who did the work. 'Course those guys were probably gone after a few months anyway...
Lyle
