floridadream wrote:
I have seen some posts here on the liquid roof and rvroofmagic so i will give you my two cents. Our shop used both quite extensively. The liqud roof we get from epdmcoatings.com is actually epdm but its expensive but does the job. Rv roof magic is also a liquid but you don't need to rush the solvent is already in the can just mix and pour out and put the lid tightly on the can and it won't get hard unlike the liquid roof. Also the rvroofmagic has higher volume solids and better elongation and is less expensive. The big difference is if you don't have a epdm roof or if someone put some other coating you do need the primer with the liquid roof but with the rvroofmagic you don't so right there you are saving $185.00 dollars. Anyway hopes that helps those posting both products
To the OP, thanks for the info from someone who's actually been there and done that. The only helpful post in this thread
