Adrian2Door's avatar
Adrian2Door
Liquid Rubber Roofing
I was planning on redoing my roof with the liquid rubber roofing. I was wondering if anyone has put it straight onto plywood instead of their old RPDM. I heard if I use multi purpose primer and cover the seams I can put the liquid rubber on to the wood. Does this sound correct and does anyone have experience with using it directly on plywood.
  • Just a thought, but even if it does work what about the weight factor added to the RV.
  • jdc1's avatar
    jdc1
    Explorer II
    You're going to be sorry. LOL. You would need about 30 coats to make it as thick as the original roof. If you'r down to plywood, I'd be looking at aluminum.
  • I just had RV Armor installed on my roof. Its not a do it yourself product because the company guarantees it for the life of the trailer and its transferable if you sell the unit. Great product. I think it can go directly on the plywood. Look up the website and call them. Invvestigate Heng's also
  • From Heng’s website...Elastomeric 100% Acrylic Roof Coating - Use over asphalt roof shingles, galvanized steel, concrete, wood, polyurethane foam and bitumas built up roof (BURs).
    But I wouldn’t.
  • I'm guessing that it won't work or, won't work very long.
    If it held up (until the warranty expired)I think the RV manufacturers would be doing it to save money.
  • in az won,t it melt and run? on a rv roof the easy way is not the best. some how water finds a way in.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
